Windshield wipers - Impala Tech
post #1 of 7 (permalink) Old 04-22-2017, 12:45 AM Thread Starter
Windshield wipers
I have a 66 Biscayne and my blades need replacing but I can't seem to find the correct 15 inch wiper refill to fit the blades. Where have you guys had success finding the correct ones? I did see that Ecklers sells a replacement blade for $15 each but my car doesn't have the typical blade. Each arm has 2 small pieces that the refills slide into. Hose two pieces then clip onto a piece of aluminum mounted to the end of the wiper arm.
camware is offline
post #2 of 7 (permalink) Old 04-22-2017, 09:09 AM
If they are originals check to see whether they are made by Anco or Trico. Last time I had trouble finding some, I turned to NAPA and to my surprise, they could not help either. But O'Rielly's did. They even had the ones I needed in stock.
Member:
-National Impala Association
62BillT is offline
post #3 of 7 (permalink) Old 04-22-2017, 09:36 AM
Rock Auto dot com has what you need:
1966 CHEVROLET IMPALA 4.6L 283cid V8 Wiper Blade | RockAuto
post #4 of 7 (permalink) Old 04-22-2017, 04:52 PM Thread Starter
Windshield wipers
Thanks for the info. I went to a local shop and they actually had some in stock. I compared them to the pics of the ones from O'Reilly and Rock Auto and they were basically the same design. The only difference I noticed were the receiver for the arm is curved on the new one while the old one has a straight piece instead. Some of the new ones only have the straight piece also but I didn't think that would be an issue.
The ones that came off the car must be an old design. I know the arms are factory style but I haven't seen any blades like these anywhere. Look familiar to anyone. The far right blade is the new one of course.
camware is offline
post #5 of 7 (permalink) Old 04-22-2017, 06:07 PM
I would say that the left ones are either aftermarket or replacements. The one on the right looks correct for your car.
Member:
62BillT is offline
post #6 of 7 (permalink) Old 04-22-2017, 07:47 PM Thread Starter
Ok thanks.
camware is offline
post #7 of 7 (permalink) Old 04-01-2020, 08:50 PM
I had the exact same blades as camware on my '65 and came across this thread before ordering the refills. Thank you Big Dave for the Rock Auto link/suggestion. I ended up ordering ANCO 1915 and disassembling them by pushing the button that says "Press to Refill", use the metal inserts from the worn blades and reassemble with new rubber. Just do one at a time so you know how to put them back together. There's probably a better ANCO 15" refill that fit these, but this worked just fine for $2.36 for the pair. Thanks!
ID:	23374   Click image for larger version
ping2lo is offline
