Alternator bracket - Impala Tech
post #1 of 17 (permalink) Old 05-16-2017, 09:24 PM Thread Starter
Alternator bracket
I recently purchased headers for a 327 and I am looking for brackets for the alternator to mount on. I was reading through the other threads and I didn't understand how the alternator mounts on the block. Does anyone have any pictures or any info that can
help me visualize it?
67impala-ss is offline
post #2 of 17 (permalink) Old 05-16-2017, 09:29 PM
You will need a Mr. Gasket Generator/Alternator mounting bracket and adapters (hollow steel tubes), to space the alternator away from the header tube, and bolted to the head.
Mr Gasket 9852 Chrome Header Mount Alternator Bracket
Looks like they don't offer anything other than the bracket today, so you will have to go the fastener section of your local hardware store to buy some 3/8th inch rolled steel tubing sections. Buy them longer than you need and cut them shorter to space the alternator out far enough to clear the header tube; but not so far as to be flopping in the breeze.
post #3 of 17 (permalink) Old 05-16-2017, 09:53 PM
Thanks Dave. We just found some pics that finally pit the main pieces together for us.
But one question for you. Where do the tubes that you are talking about go? Between the header and the bracket and having the bolts go through them? That is the only thing I can think of. The pics we saw did not have the tubes. And this makes me think we need longer bolts to accommodate that added distance? Am I thinking about this correctly?
gr8dain is offline
post #4 of 17 (permalink) Old 05-17-2017, 08:43 AM
Yes the two tubes act as a spacer since the original mount was well away from the head you need something to make up that distance and allow you to torque down the bolts without bending the bracket. I find mine at my local ACE Hardware store, but since every Ace store is locally owned they differ in what is stocked on their shelves. Neither of my Lowes or Home Depot have them.
post #5 of 17 (permalink) Old 05-17-2017, 12:20 PM
Thanks
gr8dain is offline
post #6 of 17 (permalink) Old 05-25-2017, 05:04 PM
cvfracing.com has a really nice aluminum bracket. Made in USA.
67SS is offline
post #7 of 17 (permalink) Old 07-31-2017, 08:03 PM
I installed a Alan Grove bracket on my 66 Belair. fit great no issuses. part number 215RO for long water pumps.
Name:	Alan Grove 215RO 2.jpg
CorvairV8 is offline
post #8 of 17 (permalink) Old 08-03-2017, 10:37 AM
X2 on Alan Grove. A tad expensive but top quality and worth the price.
MikeN is offline
post #9 of 17 (permalink) Old 08-03-2017, 02:28 PM
Our alternator is on the driver side. I will look to see if Alan Grove has one for that side. Thanks.
gr8dain is offline
post #10 of 17 (permalink) Old 08-03-2017, 03:00 PM
If you don't mind getting away from stock you can find a number of alternate locations to mount your alternator by trolling the salvage yards for medium duty trucks, light duty trucks and old cars as the bracket shown is just two C shaped pieces of eighth inch thick flat plate with four holes drilled in it.
Don't know what he paid for the brackets but it probably made a good down payment on a band saw that could cut thin flat stock. Once you have a desktop band saw you can cut a lot more than just one pair of brackets.
Going back to the junk yards and older cars, the alternator was bolted on in a lot of different places (low on the Corvette tucked up under the exhaust manifold opposite but in the same location of the power steering pump; and high on a truck and centered above the water outlet in the intake manifold) by the factory, plus more than just Chevys used an AC-Delco alternator.
post #11 of 17 (permalink) Old 08-03-2017, 04:31 PM
Ubderstand. Lots of options for mounting it. Just need to make sure I get a belt that works with the location.
gr8dain is offline
post #12 of 17 (permalink) Old 08-04-2017, 12:06 AM
I wouls have to look at my receipt but the price I can not remember. and yes I changed the location of my alternator. As nothing was original.
Many options for sure, this is just the path I chose. I originally came here for advice. it all worked out .
post #13 of 17 (permalink) Old 08-04-2017, 12:52 PM
GM used a short water pump and mounted the alternator on the driver's side through 1968, then started using a long water pump and moved the alternator to the passenger side beginning in 1969. Good luck on trying to find a 1968-or-earlier alternator bracket in a wrecking yard given they stopped making them that way 49 years ago, and better luck still trying to find the right pulleys to go with it.
The money spent on an Alan Grove or similar quality part is money well spent, and quite frankly, inexpensive as opposed to fabricating something or blowing a whole weekend dumpster-diving in a junk yard.
MikeN is offline
post #14 of 17 (permalink) Old 08-20-2017, 12:07 AM
I had trouble making the old school brackets work with a set of headers.
I bought this set from Summit and couldn't be happier. Problem solved and I never have to give it a second thought.
post #15 of 17 (permalink) Old 08-20-2017, 11:57 AM
Very nice brackets; but I notice that they screw into the accessory holes that he will not have on a 1967 327 engine.
post #16 of 17 (permalink) Old 08-20-2017, 12:16 PM
Good point, I forgot about some not having that.
I used to have a 327 w/ double-humps that I thought had the holes. A small glimmer of hope.
post #17 of 17 (permalink) Old 08-20-2017, 05:40 PM
1968 was the first year for the holes in the heads; even though they were not actually used until the long water pump came out in 1969. 1968 was also the first year for the large journal crank which was introduced or compelled by the 350, and why the SBC 400 has an even larger main journal to reduce the distance from crank cheek to rod journal in an effort to strengthen the crank as the stroke grew successively longer.
