62 impala 454 wiring - Impala Tech
post #1 of 4 (permalink) Old 04-11-2019, 09:28 PM Thread Starter
need diagram for basic wiring to get motor running
3 wire ignition switch
r and s solenoid
Thanks
godtar01 is offline
post #2 of 4 (permalink) Old 04-12-2019, 06:56 AM
Team Member
Details, man. What ignition setup? MSD/HEI?
68WASAGOODYEAR is online now
post #3 of 4 (permalink) Old 04-12-2019, 10:49 AM
Well in 1962 I could start up a Chevy and drive off with it with nothing more than a single wire from the battery to the coil and a screw driver to jump the starter solenoid. The snlgle wire is the bare minimum you need.
post #4 of 4 (permalink) Old 04-17-2019, 11:20 AM
The 454 is not a standard engine for 62, so I would guess your running HEI instead of points and probably an alternator instead of generator. For these things you may need to look at a late 60's impala wiring diagram. Maybe some of this will help.
https://www.hotrodders.com/forum/att...1&d=1282197808
https://www.hotrodders.com/forum/att...6&d=1310186644
