Brake light - Impala Tech
post #1 of 4 (permalink) Old 06-14-2019, 12:29 PM Thread Starter
Brake light
On my 65 Impala the brake light stays on all the time I have replaced the brake light switch and the turn signal switch neither helped any suggestions
John Mason is offline
post #2 of 4 (permalink) Old 06-14-2019, 01:10 PM
Brake pedal return spring.
post #3 of 4 (permalink) Old 06-20-2019, 05:30 AM
I would think all lights would be on if it was the pedal return spring. I think you have an inadvertent ground that will require some sleuthing.
Jim Trucksis is offline
post #4 of 4 (permalink) Old 06-20-2019, 09:14 AM
Bad ground check all the bulbs and make sure they are right and all tabs in sockets are not broke.
FireGuy153 is offline
