64 Wheel Backspace Question - Impala Tech
post #1 of 3 (permalink) Old 06-30-2019, 09:50 AM Thread Starter
I have a 64SS Impala. Someone put the wrong wheels on the car with different backspaces so two of the four wheels wont work on the front because they hit on the tie rod end. I found some with a 4" backspace that I believe came off a 63 Impala and they clear the tie rod end but not by much. Maybe 1/4". Anyone know for sure what the factory backspace is for the wheels. I'm buying new tires and want to do it right. Thanks for any info you can give me.
redrocket1953 is offline
post #2 of 3 (permalink) Old 06-30-2019, 12:09 PM
They were neutral. That is the wheel hub sat in the middle of the wheel which was narrow by today's standards. Those tires were 6.10 inch wide in the middle of the balloon sidewalls with only a four inch wide tread. They also had a bias ply construction, so they would roll under like a motorcycle tire, peeling the tread up off the pavement.
Original equipment for your car (brakes, wheels, tires) were designed for no more than 45 mph because that was as fast as you could find a speed limit back then.
Unless you plan on having your period piece towed to car shows on the back of a trailer I would be looking at bigger brakes, wider wheels and radial tires which don't look stock but can drive at modern interstate speeds without killing you or someone else.
Kelsey-Hayes still makes your original 14 inch steel wheel in it's original 5.5 inch width for sale to the reproduction market: but I would buy a Corvette wheel (doesn't have to be a Rally, plain steel works) in a 15 inch size and wider width. The Corvette still used the same front steering parts as the Impala did in 1964 (they were used up through 1982) and are also reproduced. They were rated at a higher speed than the passenger cars where.
post #3 of 3 (permalink) Old 06-30-2019, 04:52 PM Thread Starter
Kelsey-Hayes still makes your original 14 inch steel wheel in it's original 6.5 inch width for sale to the reproduction market: but I would buy a Corvette wheel (doesn't have to be a Rally, plain steel works) in a 15 inch size and wider width. The Corvette still used the same front steering parts as the Impala did in 1964 (they were used up through 1982) and are also reproduced. They were rated at a higher speed than the passenger cars where.
Thanks Dave. The car already has radial tires on it. They are P215/75R14. It rides and drives fine. I just want to get all 4 wheels the same. The originals are 14X5. I know that the wagons and 409's had a 14X6 wheel.
