68 impala no crank - Impala Tech
post #1 of 2 (permalink) Old 04-06-2020, 04:30 PM Thread Starter
68 impala no crank
I am at about my wits end.I will start with this was a running car, until it sat for a few years and everything seems to have gone to heck. One question that I have, is the yellow wire hat used to go to the coil, now goes nowhere, is this correct? It had an hei distributor installed by the po. The starter spins with 12 volts applied directly to the solenoid, but I have not been able to get anything other than that. I have the neutral safety switch disconnected and the wires jumpered, still nothing.I am thinking that the purple wire to the starter from the nss may be broken, is this logical? Any help is greatly appreciated...Mark
maybe368 is offline
post #2 of 2 (permalink) Old 04-06-2020, 04:32 PM Thread Starter
The yellow wire that I mentioned is from the R contact on the solenoid to the former coil...
maybe368 is offline
