2019 Impala Premier Auto Volume Problem - Impala Tech
post #1 of 2 (permalink) Old 05-12-2020, 08:27 PM Thread Starter
I have a problem with the Infotainment System in my 2019 Chevrolet Impala Premier with Bose 11 Speaker Surround Sound. So far I have not found anyone that can offer a solution. My issue involves the Auto Volume feature which is supposed to automatically adjust the volume based upon the speed of the vehicle and cabin noise. The settings are Off, Low, Low-Med, Medium, Med-High and High. I’ve tried every setting and none work. The only way to adjust the volume is manually. My owner’s manual makes mention of an On/Off setting for the Bose Audio Pilot System that needs to be turned On. However, my Infotainment System doesn’t have such a setting. It only has the above mentioned setting for the Auto Volume feature. One mechanic told me to contact Bose but they referred me back to the dealer. Has anyone else had this problem, or more important, do you have a solution?
Mike Millard is offline
post #2 of 2 (permalink) Old 05-13-2020, 08:43 AM
Unfortunately you probably won't find much help here as this site is for the full frame impalas from 1958-1976.
Deadwolf is online now
