How do you replace fuel lines on a 1966 Impala? - Impala Tech
 2Likes
  • 1 Post By Darth
  • 1 Post By Vintage Classic
post #1 of 11 (permalink) Old 08-06-2020, 12:41 AM Thread Starter
Do you have to remove the frame? I have a 327 motor, donít know if that helps.
Thanks.
Vintage Classic is offline
post #2 of 11 (permalink) Old 08-06-2020, 10:28 AM
No the fuel lines are held onto the frame rails by spring steel clips.
post #3 of 11 (permalink) Old 08-06-2020, 11:53 AM Thread Starter
Thanks.
post #4 of 11 (permalink) Old 08-13-2020, 03:59 PM
I replaced mine earlier this year, it's pretty straight forward. I got a one piece unit from the vendor which comes doubled over in a big box. Just take it out and carefully unbend the line and determine how to feed it back and forth to get it in the proper place. Short rubber line at the tank, and short rubber line at the fuel pump and you're all done.
Craig
66 Impala (in progress)
56 stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
craig32 is offline
post #5 of 11 (permalink) Old 08-14-2020, 12:29 AM
You did it with the body on?
Darth is offline
post #6 of 11 (permalink) Old 08-14-2020, 08:57 PM
Yes, I did.
Craig
55 Bel Air sedan
81 Corvette
craig32 is offline
post #7 of 11 (permalink) Old 08-15-2020, 12:30 AM
How did you twist it up and over the crossmember at the back in front of the tank?
Darth is offline
post #8 of 11 (permalink) Old 08-15-2020, 05:38 PM
Pretty much what you just said, twist, wiggle, shimmy back and forth - and a whole lotta swearin! That particular area was tight, but you just get it started and bend and unbend as needed. I only jacked up the pass. side, it might have been easier on a lift. It's not really a knuckle buster, but you'll definitely earn a few Labatt Blues after you tighten those hose clamps. I did it by myself in a couple hours. Good luck, and have at it!!
Craig
55 Bel Air sedan
81 Corvette
craig32 is offline
post #9 of 11 (permalink) Old 08-16-2020, 12:41 AM
Ok, thanks. I have an original fuel line in nice shape, 3/8" (I have 5/16" now) and I want to replace it. I have a lift, and I will likely swap diffs this winter to put in a posi so I was thinking that might be a good time to do it. I looked at it on the lift one day and didn't think it could be done without major bending but that gives me hope!
Thanks again.
craig32 likes this.
Darth is offline
post #10 of 11 (permalink) Old 08-16-2020, 12:41 AM
Oh, and I can't stand the taste of beer so that won't be an issue!
Darth is offline
post #11 of 11 (permalink) Old 08-17-2020, 10:24 PM Thread Starter
Thanks fellas 😎
craig32 likes this.
