White smoke and high temp! (Not covid😳) - Impala Tech
 3Likes
  • 1 Post By Big Dave
  • 2 Post By jayoldschool
post #1 of 6 (permalink) Old 09-01-2020, 06:02 PM Thread Starter
My ‘65 Impala issue:
-white smoke from one dual exhaust pipe
-that pipes exhaust seems much hotter than the other
-no oil in water and no water in the oil
-small loss of coolant
-runs but misfires at most speeds
Added K-line to seal head gasket- helped temporarily, smoke back again now but less.
Engine just got new HEI, wires and plugs(R45)
Any thoughts on the smoke and misfiring?
Thanks, Dave :-))
65whiteimpala is offline
post #2 of 6 (permalink) Old 09-01-2020, 06:08 PM
White smoke is either ATF burning or Anti-freeze. My guess is you have either a craked head/block or a blown head gasket. blown head gasket is cheaper to fix but it is still expensive.
65_&_67_Impala likes this.
post #3 of 6 (permalink) Old 09-01-2020, 08:01 PM
Pull the plugs for that side. The cylinders with the crack/head gasket will have clean insulators on the plugs compared to the other ones.
BA. and 65_&_67_Impala like this.
post #4 of 6 (permalink) Old 09-02-2020, 11:53 AM Thread Starter
Thanks to you both. I was thinking sadly the same thing. Yes, the insulator on one plug was clean compared to the others. That’s the bad news. The slightly better news is that the K-line stuff may be working! Virtually no white smoke now. But even with that, the “white smoke side” exhaust is still so much hotter than the other side. BTW, did a compression test and all cylinders were 120-130.
post #5 of 6 (permalink) Old 09-02-2020, 04:26 PM
That is bad news as a blown head gasket would show two adjacent cylinders down on cranking pressure. That leaves a cracked head or cylinder block that expands as the engine heats up.
post #6 of 6 (permalink) Old 09-02-2020, 07:16 PM
You know the problem now. All that's left to do is take it apart and find the crack.
