Dual Exhaust vs X Pipe - Impala Tech
post #1 of 5 (permalink) Old 05-24-2013, 04:11 PM Thread Starter
Send a message via MSN to Pantera
Hi Guys,
Im finally finishing my car and when i thought i finished my research for the exhaust system I came upon an issue.
I have a 283 V8 and im want to get the best loud V8 Rumble as possible, should i run dual straight pipes or x pipe (which I read increases HP).
I am interested in the sound mainly not performance.
anyone tried out both systems?
thanks
Pantera
Pantera is offline
post #2 of 5 (permalink) Old 05-24-2013, 05:56 PM
An "X" pipe is used with dual exhausts to balance the system's pressure waves. There are two basic designs for balance tubes: the "X" pipe, or the "H" pipe. The "H" pipe is cheaper because it is easier to install. The "X" pipe is better, and when properly sized (2-1/2 inch pipes) it mimics having an open exhaust in terms of flow rate which increases your power. This is because the engine sees two 2-1/2 inch pipes to flow into, which practically removes all back pressure in the system.
A dual exhaust with out a balance tubes sounds different. It can be raspy and will even go into reversion if you have a long tail pipe and suddenly back off the gas. (sounds like gas powered school bus coming to a stop).
post #3 of 5 (permalink) Old 05-28-2013, 11:38 AM Thread Starter
thanks for the answer Big Dave, I decided to go with the Oldschool dual exhaust.
Ive been browsing in youtube and found some interesting videos and I like the Dual exhaust sound better.
Pantera is offline
post #4 of 5 (permalink) Old 05-31-2013, 08:29 AM
Also, an x-pipe will give a higher pitch. Not what you're looking for.
Rick Dorion is offline
post #5 of 5 (permalink) Old 05-31-2013, 03:36 PM Thread Starter
exactly, ill post a video in a month or so when I plan to have the car finished.
Pantera is offline
