Impala Tech - View Single Post - 1966 Impala Ignition Switch
post #4 of (permalink) Old 04-28-2019, 10:14 PM
marsmann
If I understood these posts correctly, is there a chance that your 66 was retrofitted with a 68 style switch? The 66, as you know, has three positions only. Off, On, Start. If your switch is original or the correct part for your 66, then it is most likely defective and the 'in-between' setting is making contact with the start circuit, thereby consuming battery or causing a parasitic type drain.
marsmann is offline
