Impala Tech - View Single Post - 68 big block a/c brackets
post #5 of (permalink) Old 05-20-2019, 08:08 AM Thread Starter
bicster
Good info Dave. Here is what I did, Long water pump, used the fan and pullies from the small block also the power steering pump, purchased new big block alternator brackets and power steering brackets, new V-belts and they all line up perfectly. Wanted to keep the original look. If the alternator and power steering line up perfect I thought the an original set of a/c brackets would line up also. Thanks for the info. I will look for the part #'s. I purchased a new 4 row radiator so now my small block fan shroud is to wide and hits the power steering pully . Last night I trimmed off 3/4 inch from the shroud and it fits and looks good. I no longer need a fan shroud. I will post a picture. Thanks
bicster is offline
