Impala Tech - View Single Post - Rear diff yoke ID for '67 w/ 12 bolt main
post #10 of (permalink) Old 07-05-2019, 11:28 AM Thread Starter
67ImpalaSSConv
It was a highly optioned vehicle. Ac, th400 and several other options I forget. It might also have been a big block car I think from several other clues we’ve found. But there’s no way to be sure about engine size. U less you know some definitive clues
So now that I’m sure what yoke I have, is it ok to use a combo yoke with the 3r style drive shaft I found at the salvage? It is about a 3” shaft. I happened to find one the exact length I needed so it might not need cut and messed with.
Also wondering about the 3.07 gears. It seems a little high but Will that be ok with the big block and th400.
67ImpalaSSConv is offline
