Impala Tech - View Single Post - Engine runs excessively hot(in my opinion)
post #3 of (permalink) Old 07-10-2019, 06:20 PM Thread Starter
Logan
I meant it's running at low 20's while driving after it gets to 210 degrees and up. On initial start it's at 59 or so which is normal. when the coolant temp gets to about 180+ and the stat opens it's running around 40# or so. The oil pressure begins dropping very low once the temp hits 200+.
I did burp the radiator while trying to eliminate possible causes.
Logan is offline
