Impala Tech - View Single Post - Extending brake lines
post #7 of (permalink) Old 08-04-2019, 05:57 PM
wk2hons
Your main brake line for the rear coming out of the proportioning valve is 1/4". then when it reaches the rear axle it tees off to each wheel with 3/16". you may have to put a different fitting (size and threads per inch) coming out of the new proportioning valve. You can buy flaring tool sets to double flare the tubing.
wk2hons is offline
