Impala Tech - View Single Post - Poor fuel mileage
post #4 of (permalink) Old 08-28-2019, 11:39 AM
Deadwolf
Need transmission and rear ratio. The new fuel does make a difference and a good tune up will also. Going from points to MSD ignition should also help fuel mileage. If your running a power glide it is probably one of the least fuel efficient transmissions in these cars and if it even has a minor slip it will affect fuel mileage. Granted I have yet to see a stock power glide that doesn't have a minor slip. If it is a stick shift it could be more about where you are shifting to get whatever giddy-up you can get out of it. 327 likes to produce power at higher RPM where your engine uses more go go juice.
