Impala Tech - View Single Post - Factory Fitted Caliper Help ?
post #2 of (permalink) Old 01-06-2020, 01:36 AM
I would retain the lip seal cups. With stainless steel sleeves you should no longer have corrosion problems. Just remember to change the brake fluid with a full flushing of system every two years or so to get rid of any moisture the brake fluid picks up.
Since the Girling style brakes were used on the Corvette from 1965 through 1982 a Corvette board will have the definitive answer to your question as to the pros and cons of modifying the brakes.
