Rivets/welding EDP - Impala Tech
Body Shop Paint & Body Forum
 3Likes
  • 1 Post By Big Dave
  • 1 Post By gnfast87
post #1 of 8 (permalink) Old 03-22-2019, 11:02 AM Thread Starter
Rivets/welding EDP
I'm replacing floor pans in 66 Impala and the replacement pans are coated in EDP. Can I pop rivet? If I weld, do I need to remove EDP surface before weld? Does that ruin the coating? Thanks in advance!!
Impala 66
Dennis Bouvier is offline
post #2 of 8 (permalink) Old 03-22-2019, 11:26 AM
You can not pop rivet the pans in, they must be stich welded (MIG or TIG). You should grind the EDP coating off with a red Scotch bright wheel Then weld before priming it with self etching primer.
BA. likes this.
post #3 of 8 (permalink) Old 03-22-2019, 01:27 PM Thread Starter
Ahh, ok. It's funny, doing this as teenager helping friends out with cars, we'd pop rivet everything!! Now with the internet I can learn all the reasons as to why that's wrong, lol
Ok, grind, prep, and weld.
Any coating I should put in after everything is welded and grinded smooth?
Impala 66
post #4 of 8 (permalink) Old 03-22-2019, 02:21 PM
Self etching primer bonds to bare metal; but it needs to be be covered with either high build primer then paint after that, as self etching primer is porous (water goes right through it).
Dennis Bouvier likes this.
post #5 of 8 (permalink) Old 03-28-2019, 05:08 PM
Pop Rivets
Here's what I did when I replaced the floor of my 68. Stitch weld in the pans like Dave said then I applied Evercoats waterproof Everglass Kevlar reinforced filler in all the seams (both inside and under seams). Then rollered on a coat of Nason Epoxy Primer. That stuff is hard as rock when dry. Scuff sanded the epoxy after a couple of days and sprayed semi gloss black over top the Epoxy. Came out perfect and I don't think I will ever have another issue with rusting floor pans again.
Brian
gnfast87 is offline
post #6 of 8 (permalink) Old 08-29-2019, 04:11 PM Thread Starter
Well...that's something I only want to do once!! Lol 😁 I see I started this in March. It takes a lot of time to cut out a floor and put a new one in!!!!. I know that now 😬
ID:	22672   Click image for larger version
ID:	22674   Click image for larger version
ID:	22676   Click image for larger version
Impala 66
post #7 of 8 (permalink) Old 08-29-2019, 06:08 PM
That is why I would have rather built a dominating street motor for the body shop tech and have him do the work foe me.
post #8 of 8 (permalink) Old 08-30-2019, 09:32 AM
Big job but the results are pretty fantasic.
