Control arm connects to the axle - Impala Tech
Body Shop Paint & Body Forum
post #1 of 7 (permalink) Old 08-29-2019, 05:19 PM Thread Starter
What's my best plan here? Should I patch and weld? Can I buy a replacement bracket to weld to axle? I really would rather not replace rear end.
ID:	22680   Click image for larger version
Impala 66
Dennis Bouvier is offline
post #2 of 7 (permalink) Old 08-29-2019, 06:55 PM
You have some serious corrosion issues. The tube is a stressed member of your suspension with pits and holes that deep (the tube is only 3/16th inch thick) I would worry about structural failure. You can buy a nre Pan Hard br mount, but I would be more worried about the rear end.
Just Google fully welded rear end, and broken plug welds to see how much stress is on the rear end.
post #3 of 7 (permalink) Old 08-30-2019, 10:09 AM
Agree. With all those pits, I would be looking to change the whole rear and any effective parts related to it.
Member:
-National Impala Association
62BillT is offline
post #4 of 7 (permalink) Old 08-30-2019, 10:29 AM
Agree that is shockingly pitted.
I've never seen a replacement control-arm mounting bracket so I think you'd have to have one cut and welded in place. Actually, that may be the easy part just getting metal from Lowes/Home Depot and a air-tool grinder.
The harder thing might be welding to that rear-end and NOT blowing a hole through the pitted, thin axle tube. If you have a low performance motor and an automatic, you may be able to get away with just that bracket replacement. Still some risk in that though as they already noted.
post #5 of 7 (permalink) Old 09-01-2019, 08:12 PM Thread Starter
Well, guess it's time to look around for a "used, but better than what I got" rear end. It is the weakest link in my setup, tranny is good, engine is good, it's a 350 out of 78 Camaro.
From quick shopping around, I see more 12 bolts than 10 bolts. I have a 10 bolt 8.2 in there now, if I got a 12 bolt, would I have to upgrade drive shaft as well?
Impala 66
post #6 of 7 (permalink) Old 09-01-2019, 08:50 PM
Just make sure it's not a truck 12 bolt. They're cheap and easy to find... and they're too big for your car.
post #7 of 7 (permalink) Old 09-02-2019, 10:51 AM
Same driveshaft. Same everything other than the 12-Bolt itself. Has to be from a B-Body Chevy though for a direct and correct bolt-in. A '65-'70 Rear will fit your '66. They are a little hard to find and a little pricey as well. A 10-Bolt would be cheaper and easier to find and also remember the Ratios can be different which ever one you decide on.
Member:
62BillT is offline
