67 impala 700r4 swap - Impala Tech
post #1 of 3 (permalink) Old 08-16-2009, 12:51 PM Thread Starter
I have a 67 impala 4 door with 300hp 327 and a powerglide is a 700r4 from and 86 chevy 2wd pu bolt up and if so what mods will I need to do. I have the 86 chevy just for parts. I am new to this site any help would. Thanks For the help and hello to everyone.
Also I would like to know. Can I run my 700r4 with out using the o/d for a while. Not wireing up the tourge converter lockup cant afford kit yet but I want to drive car any help would be great.
ScottImpala67 is offline
post #2 of 3 (permalink) Old 08-16-2009, 01:40 PM
Welcome to the Team Scott!
The tranny will bolt to the block no problem (all Chevrolet transmissions share the same bolt pattern on the bell housing). The 700R4 tranny is longer over all so the drive shaft will need to be shortened and the cooling lines have a different O-ring seal instead of an inverted flair compression fitting (but NAPA sells adapters). There are also differences in that all of the bolts on an '86 tranny are Metric (including the flexplate and converter bolts) as well as the fact you are adding a gear so your linkage has to modified or replaced (available mail order from repop houses). You will need to keep the converters together (the PowerSlide keeps it's converter and the 700R4 keeps it's lock up converter. That's about it. Cutting down the overall length of the drive shaft is the only real biggy.
post #3 of 3 (permalink) Old 09-09-2009, 12:45 AM Thread Starter
thanks big dave your help was very useful
