New guy - Impala Tech
 2Likes
  • 1 Post By Big Dave
  • 1 Post By 68WASAGOODYEAR
post #1 of 6 (permalink) Old 11-15-2019, 10:55 AM Thread Starter
New guy
Hello and thanks for the add. I am the proud owner of a 66 2 door coupe with alot of questions. I am in the beginning of a complete body off resto for the 2nd time in 30 years. Look forward to the wisdom and knowledge of my fellow impala owners
Rpinney1 is offline
post #2 of 6 (permalink) Old 11-15-2019, 10:59 AM Thread Starter
Bear with me as i learn this site. Took me awhile just to figure out how to post. My 1st qusetion in a line of many is i am redoing my 66 frame. Complete teardown and rebuild. When replacing bushings in the front and rear control arms do the outer sleeves need removed ?? I am finding bushings online with a note to reuse the sleeves but the OEM moog bushings appear to have the outer sleeves with them as one unit. Thanks
Rpinney1 is offline
post #3 of 6 (permalink) Old 11-15-2019, 02:12 PM
Yes, remove the current outer sleeves. Burn out the bushings with a torch and then beat the small flange of the sleeve inwards with a metal punch. Do this around the diameter of the sleeve and then remove it. If I remember correctly, the new bushings will be bonded to the new sleeve and have to be installed as an assembly.
post #4 of 6 (permalink) Old 11-15-2019, 02:29 PM
Welcome to the team!
You can buy a cheap Chinese pres for around $100 at Harbor Freight. Just be sure to place a socket between the flanges of the control arm to prevent the flanges being crushed as you press in a new bushing.
BA. likes this.
post #5 of 6 (permalink) Old 11-15-2019, 02:35 PM
I put the new bushings in the freezer overnight and then used the aforementioned torch to heat up the control arms. I was then able to basically beat them in with a piece of a 2x4 and a 5lb sledgehammer. Not elegant, but it worked.
BA. likes this.
post #6 of 6 (permalink) Old 11-16-2019, 11:05 AM
Welcome to the site!
Share some pictures of what you are starting off with when you have time!
