64 2dr HT with wheel hop - Impala Tech
post #1 of 8 (permalink) Old 02-27-2007, 11:19 PM Thread Starter
I have a nice looking 64....Currently with a warmed up 350, a muncie 4 sp. and a 4.10 posi rear end. I get an extreme amount of wheel hop when accerlerating from astop. Last summer I replaced all the shocks...no change. My next option would be a rear stabilizer or traction bar....Has anyone else has this problem?
A friend said it is due to the rear coil springs....
What would you all do?
uniquebrett is offline
post #2 of 8 (permalink) Old 03-24-2007, 11:26 AM
Put in some new bushings. Is the back of the car higher than stock? If so lower it.
Jim
77 Monte
385- AFR 190's Clay Smith solid--200-4r w/ 3.73's
67 Imp.SS for the wife 275 hp 327-TH350
http://myweb.midco.net/77cruiser/
77 cruiser is offline
post #3 of 8 (permalink) Old 03-25-2007, 06:12 AM Thread Starter
all stock suspension
My car is all stock except for the engine and transmission. I think I would rather put in traction bars than just replace the bushings and have the problem come up again after time and use. An suggestions on this?
post #4 of 8 (permalink) Old 04-14-2007, 06:50 PM
3 or 4 link ?
I have a 64 with the same set up & I have no problems. Im wondering whether you have a 3 or 4 link rear end set up . mines a 4 link.
64lowrod is offline
post #5 of 8 (permalink) Old 04-16-2007, 12:32 PM
Do you have heavy duty springs in the rear? Stiffer springs (or air shocks) tend to make wheel hop worse, you might try a pair of softer springs.
Bob
bobss396 is offline
post #6 of 8 (permalink) Old 04-25-2007, 09:48 PM Thread Starter
I think mine is a three link system....It has tow lower control arms, and one control arm on top of the rear axle, but it also has a panard bar going across the back side of the rear axle.
As for the springs ...I dont know ...how do I tell if they are heavy duty....I am sure that they are factory originals. No air shocks....just factory replacements from Oreillys.
I have decided to replace the bushings on the rear end....where should I get them for the best price?
Brett
post #7 of 8 (permalink) Old 06-07-2007, 08:26 PM
I got mine from P.S.T. you can get either rubber or poly.
64lowrod is offline
post #8 of 8 (permalink) Old 06-07-2007, 11:31 PM
Wheel hop is a combination of all of the above (tire pressure and compound, spring rate too hard/soft; worn control arm bushings or using polypropylene bushings that bind; and having shocks that are too firm or not firm enough) I need to add to this is a built in design problem called a jet smooth ride. You may need to raise the attachment point of the upper rear control arm on the axle end to point your torque where it will do the most good (transferring weight to the rear tires).
Sounds easy huh?. You will need to evaluate what is actually going on by having someone tape your launch (hopefully with a camera that has a slow motion option). Then change only one thing at a time to see what the effects are.
I would start with the control arm bushings because that wheel hop applies upon sudden braking as well and could be a safety issue.
