header issues - Impala Tech
post #1 of 3 (permalink) Old 06-05-2007, 10:04 PM Thread Starter
header issues
does anyone have any suggestions for a set of headers for my 64 imp? im running a 383 s/b with dart iron heads with angle plugs. the problem is that with the chinese made block-huggers is that the plug boots are to close to the tubes. the car also has power steering & power brakes.
64lowrod is offline
post #2 of 3 (permalink) Old 06-06-2007, 02:35 AM
Block huggers may be a problem (as you have discovered) with angle plug heads. Have you tried the stubby Accel plugs to get around this close fit issue? Because they are rebranded lawn mower plugs they have a limited heat range, but should work with a street set up.
post #3 of 3 (permalink) Old 06-07-2007, 08:23 PM Thread Starter
Dave i'll give those accel plugs a try. thanks.
64lowrod is offline
