Will it fit? - Impala Tech
post #1 of 3 (permalink) Old 12-12-2010, 02:50 AM Thread Starter
Will it fit?
Hi, wondering if anyone knows if an Edelbrock Street Tunnel Ram with Holleys and small cleaners on a Big Block will fit under a 4" cowl hood in a '66. Any pics appreciated. Cheers.
67cammy is offline
post #2 of 3 (permalink) Old 12-12-2010, 08:51 AM
The top of the carbs fuel bowl will be above the top of a stock flat hood by about 3/4 inch on the front carb so it will be a close fit. The cowl hood scoop drops down in the front just about where the front carb is the highest. Most persons runing a tunnel ram have a much higher scoop than four inches. Usually one with a front opening since there is no benifit to a rear opening scoop once you get above four inches tall, and you loose the high pressure area at the base of the windshield.
post #3 of 3 (permalink) Old 12-12-2010, 03:10 PM Thread Starter
Thankyou Dave. Good info.
67cammy is offline
