409 hp for 63 - Impala Tech
post #1 of 5 (permalink) Old 12-31-2005, 03:01 PM Thread Starter
409 hp for 63
What was the hp for the 409 in 63?
BudW is offline
post #2 of 5 (permalink) Old 12-31-2005, 06:33 PM
I have an engine data chart in one of my books that lists 3 different 409 engines for 1963. They are all 11.0:1 compression. The first is 340hp, and is the only one of the three that was mated to a powerglide trans. The second was 400hp, had a single 4 barrel carb, and only came with a manual trans. The third is 425hp, had dual 4 barrels, and only came with a manual trans as well. Hope that helps.
Bing
1956 Chev 150 2dr sedan 302ci
1965 Chev Malibu 2dr hdtp 496ci
1967 Chev Camaro 327ci
2001 Harley XL1200C
2002 Chev 2500HD
post #3 of 5 (permalink) Old 01-01-2006, 02:39 PM Thread Starter
Thanks For the help Just what i was looking for!
Ty
BudW is offline
post #4 of 5 (permalink) Old 01-02-2006, 12:13 PM
My old "book of numbers" list 5 different suffex codes for 63 as followes:
QA- Man trans 4BC
QB- Man trans Dual 4BC
QC- Man trans
QG- Powerglide
QM- (RPO Z11)
goldragtop is offline
post #5 of 5 (permalink) Old 02-04-2006, 11:23 AM
Compression on 409s in 63
I think the 340 horse 409 was 10:0-1 on compression. Only the HP were 11-1, and then only after removing one head gasket. They came from the factory with 2 gaskets per head, and about 10.2-1 compression. You removed one of the steel shim gaskets and had 11-1 compression. The 340 horse had a cast piston and was lower compression.
Fred
SS425HP is offline
