Impala Tech - View Single Post - Upper control arm 1964 impala
post #4 of (permalink) Old 07-07-2012, 03:46 PM
dcairns
To remove the shaft, you have to loosen two clamp type bolts. The top one near the "U-joint".
The silver clamp and nut/bolt can be seen here
What the U-joint looks like with the clamp and shaft removed. Notice the cut out for the clamping bolt to pass through. If memory serves, there is a groove in the shaft to keep the shaft from slipping up or down. So the bolt must be removed entirely for the shaft to slide out.
There is another clamp style bolt below the rag joint, it has a spline style head and clamps the rag joint to the steering box. With those loose, you should be able to remove the steering shaft (remember the u-joint slides a bit
The steering box shaft has a similar groove, so remove the spline head bolt all the way as well.
