1968 2 door hardtop rear window interior trim - Impala Tech
post #1 of 4 (permalink) Old 08-31-2015, 12:41 PM Thread Starter
Can someone please post a picture or explanation of what the interior trim looks like around the rear window of 1968 2 door hardtop (not a fastback)?
I inherited the car and it was already removed and I think I'm missing the corners maybe? I have three metal pieces: one long arc-shaped piece and two L shaped pieces that overlap and screw together in the middle. Seems like there should be corners or something to connect it all together, but I've never seen one finished.
Any help would be appreciated - thanks
MyDads68SS is offline
post #2 of 4 (permalink) Old 10-22-2015, 01:54 PM
Don't know if you are still looking for help with this ??
I've searched the net and can't find any pics of a rear window...
Have you tried holding the pieces up on the outside and see if there are gaps where corners would be missing ? If you look at the outside trim on the windshield, they fit under the upper trim in a "slot". See if the long arc piece has those slots in the ends for the L shaped pieces to fit under.
'62 Impala SS 409 TH350
'66 Chevelle SS 496 M20
'70 Chevelle SS 396 M20
'67 Camaro ss/rs 350 PG
'38 Chev coupe street rod
'54 Chev 210 2 door
'69 Chev C10
'89 Chev R3500 roll back
Lost in the 60's is offline
post #3 of 4 (permalink) Old 10-22-2015, 06:51 PM
Welcome to the Team Mike!
The Fisher Body Service manual may be of help in identifying trim pieces and how they are assembled as well.
http://www.themotorbookstore.com/196...FZUWHwod9B8KnA
post #4 of 4 (permalink) Old 12-08-2015, 11:31 PM
Trim.
If you can send me pics of what you do have. I should be able to I.D. What you have. And I most likely have whatever pieces you need
snoopy1 is offline
Tags
1968, interior, rear, window
