where is it? high beam indicator light on dash - Impala Tech
post #1 of 4 (permalink) Old 10-28-2011, 11:07 AM Thread Starter
where is the high beam indicator light on dash for a 4dr 64' belair. the bulb maybe burned out. cant tell if they are high are low(yes I can tell when the sun is all the way down). I hit the switch getting in and out so when I turn them on I have no clue.
rreynolds is offline
post #2 of 4 (permalink) Old 10-28-2011, 11:41 AM
On my 65 there is a red rectangle that illuminates above the speed numbers that says "BRIGHTS". If you shine a flashlight at the face of the dash, you should be able to see it, if a 64 has that feature.
post #3 of 4 (permalink) Old 10-28-2011, 02:05 PM
It's either above or below the speedometer. I can't remember which off hand. When on high beam all 4 lights should be on, and on low beam you should only have the outside lights on.
05snopro440 is offline
post #4 of 4 (permalink) Old 10-28-2011, 10:24 PM
