stock distributer on a '64 impala - Impala Tech
American Auto Wire
post #1 of 4 (permalink) Old 01-29-2012, 08:17 PM Thread Starter
i recently picked up your complete harness kit for my '64.....is it possible to run the +coil wire through the resistor and to the coil then to the stock distributor???? just curious if it is do-able or if i should just break down and get a new distributor.
impalaguy327 is offline
post #2 of 4 (permalink) Old 01-30-2012, 08:18 PM
Rodney American Auto wire doesn't read these boards much (I do not recall them ever posting anything but an ad).
Your stock wiring had a ni-chrome resistor wire that ran from a junction on the fire wall (there was a big plastic ferule that would be visible where the resister wire spliced into the regular copper wire) that dropped the voltage down from a nominal 12 Volts to 8 Volts. If your new replacement wiring is all copper (which is a good thing if you ever want to upgrade to an HEI distributor) you can use the same ballast resister that the 1955-'57 Chevys used on their firewalls; as they are available as a service part, and it does the same thing as the old resistor wire.
Only your information (instruction sheet) can answer this question or a call to American Wires tech line.
post #3 of 4 (permalink) Old 01-30-2012, 10:29 PM Thread Starter
oh...good to know that about this company, thanks again!
post #4 of 4 (permalink) Old 02-04-2012, 11:43 AM
Go here:
http://www.chevytalk.org/fusionbb/sh...ican_autowire/
Tom
1965 Impala SS Tahitian Turquoise 427 4 Speed
427SS65 is offline
