Impala Tech - View Single Post - 1965 Impala SS Front Disc Brake Conversion
post #3 of (permalink) Old 08-14-2013, 04:40 PM
Welcome to the Team Juan!
The only 14" inch wheels that will clear a stock single caliper GM caliper on an 11" rotor where used on a Nova, Camaro or a Chevelle. These are all steel 14 by 6 or 14 by 7 inch wheels with neutral back spacing and five lug on 4-3/4 inch bolt circles. These wheels are rare and expensive. They will also tear up your tires when they are being mounted by a tire machine operated by a minimum wage teen age temp worker as there isn't a bead well for the tire bead to drop into. Here is what the difference in the wheels looks like:
http://i51.photobucket.com/albums/f3...z/P1000912.jpg
All disc brake equipped big cars came with 15 inch wheels (usually Corvette Rally wheels) because the brakes that Chevrolet used on your car (1965-'70) from the factory came off of a Corvette and used a Girling four piston brake caliper.
If you want to use the CPP single piston GM caliper brakes off of a mid eighties A or G-body car (intermediate sized not designed for a full sized car) then you will need to find a 14 flat bottom steel wheel or a 14" Rally wheel for a disc brake Camaro or Chevelle from 1969-'74 that wasn't a Z/28 or SS as they all used 15 inch wheels starting in 1969.
If you don't want to spend the rest of your lkife looking on e-Bay for these wheels this company finds and resells them:
http://www.classicchambered.com/classic/wheels.html
