Ignition switch - Impala Tech
Site News Announcements
post #1 of 2 (permalink) Old 10-04-2015, 03:27 AM Thread Starter
Ignition switch
Today I went to replace my ignition lock cylinder. I drilled out the old one but the new lock cylinder I bought wouldn't fit in the ignition switch. I could still use a screw driver to turn the car over. As I was driving the car lost power and I could not get it to turn back over. I was just wondering if this could be a problem with the ignition switch itself causing the car to die and not start back up. The car was running and driving fine before the ignition switch modification.
Also as it was being towed home it had been put in reverse instead of neutral. It caught twice before we realized what had happen. There was a strong smell of gas. We went less than half a mile at low speeds. Any ideas at the damage that could have been caused by this and anything in particular to look for? Thank you
TPress is offline
post #2 of 2 (permalink) Old 10-04-2015, 08:47 AM
Switch
On a 66, in order to pull the ignition switch lock, you place your key in the switch, then a paper clip in the hole next to it and turn the cylinder and the lock pull out, same to repalce it. I'm not sure if any damage occured drilling out the cylinder, but if not you install in the same manner.
As far as any damage due to it being in neutral, should not prevent the car from starting.
Paul
Paul
1966 Impala SS
Please Visit our new site:
http://www.winvoices.com/
fsc66 is online now
