1969 Impala Vin# help - Impala Tech
post #1 of 7 (permalink) Old 12-11-2008, 11:34 AM Thread Starter
Question 1969 Impala Vin# help
Researching our 1969 impala we've run across some conflicting numbering. The vin and the protecto plate number are only one number off (the year).
vin # on impala 164677S110510
protecto plate 164679S110510
Body Tag ST69 STL321223BDY 50PNT TR866.
this is a 1969 body style impala but the vin #stamped would indicate it is a 1967
any thoughts or help
huff4825 is offline
post #2 of 7 (permalink) Old 12-11-2008, 02:40 PM
That is weird. What is the rest of the number following the style number on the cowl tag? (ST 69-xxxxx) Should be 16467.
Built at St. Louis plant. It would appear to be a typo since the production numbers match. (110510)
1968 Caprice 396 is offline
post #3 of 7 (permalink) Old 12-11-2008, 02:48 PM
Style: 6916467
Year: 1969
Series: Impala
Body Style: 2-Dr Convertible
Engine: 8 Cyl
Body: 321223
Serial #: 223
Trim: 866
Series: Impala/Custom
Interior Color: Red
Material: Vinyl
Paint: 50
Color:
Upper Body Color: Dover White
post #4 of 7 (permalink) Old 12-14-2008, 01:23 AM
Have you checked the frame VIN number? - it's probably on the passenger side, top of frame rail, behind the rear wheel hump. May be hard to see if rusty.
Tom
1965 Impala SS Tahitian Turquoise 427 4 Speed
427SS65 is offline
post #5 of 7 (permalink) Old 12-14-2008, 04:35 PM Thread Starter
Thanks I'll have to check it out & see if I can read it.
huff4825 is offline
post #6 of 7 (permalink) Old 01-17-2009, 03:26 PM
Can you post some pictures of the trim tag, vin tag and protectoplate? It may simply be a factory mistake.
Warren
TAR6569 is offline
post #7 of 7 (permalink) Old 06-04-2010, 05:09 PM
vin tag replacement
Hello to you all
I bought a 67 impala full of rust and a lot of pieces missing. one of this is the vin tag. Do you know where can i find a vin tag replacement' The car is tottaly legal with all the papers and so.
I'm in Europe
Thanks in advance for your help
charles
butio is offline
