1963 Bel Air wagon acc code E29??? - Impala Tech
post #1 of 4 (permalink) Old 09-07-2020, 10:44 PM Thread Starter
Hello, I just registered because I cannot find what E29 means anywhere.
My car is a strippy laurel green 63 Bel Air wagon 6 passenger with a 283ci 2bbl, 3 on the tree and radio delete.
Does anybody else have a factory radio delete car? If so, does it have E29 on the cowl tag?
Any help would be appreciated.
There are no other acc codes on my tag at all.
Thanks!
31635Lxxxxxx is offline
post #2 of 4 (permalink) Old 09-08-2020, 07:43 AM
The E is most likely tinted front glass.
The 29 looks like it might be courtesy lights under the dash. So instead of just having dome lights does your car also have lights under the dash that light up the floor in the front when you open your doors?
post #3 of 4 (permalink) Old 09-08-2020, 09:18 PM Thread Starter
@Deadwolf
Thank you very much for the reply. I'll check when I get home tonight and let you know!
post #4 of 4 (permalink) Old 09-10-2020, 07:58 PM
On 1963 cars built at Van Nuys California (and no other Fisher plant in 63) the ACC codes included a date as well as options, so in this case E is for tinted glass (all windows) and the 29 is the date the cowl tag was stamped, which means April 29, 1963 - which aligns with the date code. It's not known why Van Nuys did this.
Carl 1962 is offline
