64 Cowl Tag Decode?? - Impala Tech
post #1 of 7 (permalink) Old 01-08-2008, 11:32 PM Thread Starter
I have a 64 Impala SS convertible that I am just starting a frame off restoration on. I need help decoding the Accessory codes on my cowl tag. Here is my tag info:
03A
Style 64 1467 SLO 1269 Body
Trim 879 1 922 Paint
W2LSR
I already know this is a red on red Impala SS convertible built the first week of March 1964 in the St Louis Plant. I need help with the W2LSR accessory codes. I have dug up some info and belive the L reprsents a 4 speed, the R represents a rear seat speaker, and S represents a rear antenna. Does anyone know if this is correct or what the W or 2 represent? The tag also has a "16" stamped on it after the accessory codes, does anyone know what this means?? Thanks for your help. Nick
nschollmeyer is offline
post #2 of 7 (permalink) Old 01-10-2008, 12:11 AM
Send a message via Yahoo to 348-4speed
03A
W2LSR
You are correct in your findings but I also think the W=tinted windshild only. Here is a link that may help. Good Luck.
http://www.348-409.com/acc2.html
348-4speed is offline
post #3 of 7 (permalink) Old 01-23-2008, 03:44 PM
03A
W2LSR
Hi Nick, the W is Tinted Windshield. The 16 is a handstamp I believe done by someone inspecting the car. I have made a list of the handstamps i have seen and the pattern is that you see the lower numbers on 2drs and the higher number on 4dr sedans and sport sedans. The highest numbered handstamps I have seen are around 63 and 64 and they were used on wagon. There are some exceptions though. Whats the vin on your car? I would like like add it onto the 64-70 fullsize chevrolet registry.
BTW, the 2 you asked about designates group 2 for the option. There are 5 groups. The 2L code is for M20 wide ratio 4spd only.
What engine does the car have and you have any original docs from it.
Warren
TAR6569 is offline
post #4 of 7 (permalink) Old 01-23-2008, 03:45 PM
FYI, some of the codes in that list are incorrect. If anyone has any questions, email me. Some of the codes that show blanks on that list I have decoded.
Warren
TAR6569 is offline
post #5 of 7 (permalink) Old 01-03-2017, 12:20 PM
Im looking at a 1964 Convertible with a 409 in it and the ACC line reads 2M , 2S , 5V . If im correct the 2M line states it came with a powerglide transmission. It has a 4 sp in it now and wondering if I am correct about the codes and if they mated the 409/425 to a powerglide from the factory?
jamride is offline
post #6 of 7 (permalink) Old 01-04-2017, 04:42 PM
No 409/425 with PG trans. Is it supposed to have the original engine?
TAR6569 is offline
post #7 of 7 (permalink) Old 01-10-2017, 01:51 PM
Cowl plate
Vehicle Identification Number (VIN) and Cowl Tag Decoding ? Impalas.org This site helps you decode your vin and cowl plate, it help me decode mine.
JuniorL is offline
