Lower Steering Column Bearing??? - Impala Tech
post #1 of 8 (permalink) Old 05-04-2018, 10:17 PM Thread Starter
Hello all,
1968 Impala
396/TH400
Column Shift, non-tilt
The lower steering column bearing in my car is SHOT - not concentric at all with the steering shaft. Does anyone know a source for these? Exhaustive google searching has turned up nothing...I'm getting a bad feeling about this one.
Thanks in advance for any replies.
post #2 of 8 (permalink) Old 05-05-2018, 01:28 AM
I looked it up in the GM parts book, 7806142 is the GM number. Maybe you can find something that way. My 66 is different but I when I did the lower bearing on it this past winter I went to ebay, punched in the number for mine and found an NOS bearing for $15. Maybe you will be lucky too.
Oh, and it's the same as 68 Camaro and Chevelle, so maybe that will help your search.
Darth is offline
post #3 of 8 (permalink) Old 05-05-2018, 01:31 AM
Oh, and 7802186 is the older number for that part. However, to be safe I think I'd stick with 7806142. 67-68 use the same bearing and 7802186 is listed for 67 only.
Darth is offline
post #4 of 8 (permalink) Old 05-05-2018, 07:22 AM Thread Starter
Thanks a ton darth. Will give it a try.
post #5 of 8 (permalink) Old 05-05-2018, 07:29 AM Thread Starter
Found one on ebay for $79. Ouch. Doesn't look identical to what I took out, but I'm out of options otherwise. Will update.
post #6 of 8 (permalink) Old 05-06-2018, 01:06 AM
Yeah, I searched a bit and I think the best I found was $60. Seems hard to believe but maybe that's what they cost...
Darth is offline
post #7 of 8 (permalink) Old 05-06-2018, 09:56 AM
A case of supply and demand. You can take you old bearing down to a Fafnir or Timken warehouse located in your town and see if they can match your bearing with one in stock for another application. If so post that application here so others will know what to order.
I miked my old bearings to rebuild the transmission in my 1947 John Deere tractor (original service parts discontinued) and found matching bearings off of industrial fans to Isuzu trucks to replace them.
post #8 of 8 (permalink) Old 05-07-2018, 10:08 AM
I believe I saw something similar to what your describing at the website for IDIDIT or Flaming River. (back when I was shopping for a new steering column)
They probably aren't cheap, but, it's a possible alternative.
