64 Impala SS - factory cruise control - Impala Tech
post #1 of 6 (permalink) Old 05-14-2016, 02:23 AM Thread Starter
Restoring my 64. If possible I would like to find a complete factory cruise control system. Where do you suggest I look? I assume Chevy doesn't make the kit. If anyone has one for sale out there please respond either here or my personal email. [email protected]. Thanks.
Rwood_devil is offline
post #2 of 6 (permalink) Old 05-14-2016, 11:22 AM
Prior to electronic transmissions the cruise control use took input from the speedometer cable to use a vacuum solenoid to pull the throttle back for cruise control. Everything under the hood could be easily transferred to your '64. What you will have a hard time doing is finding the original dash mounted control switch to set the device as newer cars used a steering column mounted switch on the turn signal stalk.
post #3 of 6 (permalink) Old 05-14-2016, 11:53 PM Thread Starter
Thx for the reply. I see you are a moderator and respond to many posts. As a novice owner I really appreciate what you do for me and others like me. I've waited 30 years to get a cruiser and chased this car for 5 yrs. if I knew how to send a pic I would.
I ask one more question no one has replied to yet. I purchased a factory tach but I have an aftermarket tilt wheel. My mechanic says it will not sit deep enough in the dash to look right. Anyone else run into this and is there a fix? The 64 tach location is iconic.
post #4 of 6 (permalink) Old 05-15-2016, 10:48 AM
Most tachs were dealer installed Dixco tachs with a licensed Chevy Bow Tie. They were mounted on the column angled down about forty five degrees and held in place with a screw type stainless steel hose clamp.
Dixco and Sun were amongst the first electronic tachometers made. In 1964 Chevy was still using a mechanical tach driven off the distributor as electronic (transistors had just recently been unintentionally declassified by the Japanese who had copied the transistorized circuits found in Lockheed's F-104 Starfighter jets stationed in Japan). Transistors had been a military secret up until Japanese transistor radios suddenly appeared on the market.
To Quote Gomer Pyle USMC "Surprise, Surprise, Surprise!" If you have ever read Sun Tzu's book "The Art of War" you would understand how our ally could treat us this way, and why we should not have forgotten what happened at Pearl Harbor. But that is history for you.
post #5 of 6 (permalink) Old 05-16-2016, 10:20 AM
You have to cut the dash to install the tach. There is a template that can be purchased to make the cut correct.
Madencali is offline
post #6 of 6 (permalink) Old 05-16-2016, 05:16 PM
I don't know if they're the same... but these are on eBay for a 65-66 car. Good Luck.
1964 1965 1966 Chevrolet Corvair Cheyenne El Camino Cruise Control Tag | eBay
1965 66 Chevy Impala Caprice Delco Speed Cruise Control Assembly | eBay
1965 1966 Impala SS Caprice Cruise Control 396 409 427 Super Sport | eBay
Chris
Warrenton, OR
'70 Chevelle
'74 Nova
'10 Camaro
jayhawk500 is offline
