Body side moulding retainers - Impala Tech
post #1 of 5 (permalink) Old 01-26-2020, 06:37 PM Thread Starter
Does anyone know where I can buy these retainers? They hold the side moulding on the 1967 Bel Air. Most of them did not survive the removal process. Thanks in advance!
File Type: jpg B6F11E66-CA14-4C8B-B43E-36091F28D541.jpg (32.8 KB, 18 views)
File Type: jpg 10507C64-769B-4902-9D92-CFFA413AE925.jpg (24.2 KB, 18 views)
File Type: jpg 7FFA17E7-4415-4950-BC24-DB948F2F3D93.jpg (23.2 KB, 18 views)
File Type: jpg D1A81580-97E4-4C3F-9EA8-7F48C3AEAF27.jpg (19.5 KB, 17 views)
67 Sedan is offline
post #2 of 5 (permalink) Old 01-28-2020, 07:30 PM
This is the closest I could find, for a '66 though. Maybe these could work? They also look similar to the plastic clips pressed into the doors to fasten door panels:
https://www.lategreatchevy.com/full-...pala-1966.html
What do the clips inside the trim look like? I'm assuming they have the sharp pointy bit that gets hammered through the plastic things. Could you use a different style of clips, maybe one that has a threaded fastener?
post #3 of 5 (permalink) Old 01-29-2020, 12:25 PM Thread Starter
68wasagoodyear
There arenít any clips on the trim side. These have a lip that slides on the trim and then pushes into the body. Same holes as your 68. What do your clips look like? I found these and ordered some, might get them today. If they fit, Iíll order more(need 32 total). They measure darn close, just missing the metal support. Plus the few I salvaged are 53 years old and fit a little loose. Thanks!
File Type: jpg D3CF3192-4685-4404-9DD9-5DFF80D07EB0.jpg (48.0 KB, 11 views)
File Type: jpg EF23E351-B56D-483E-AA53-F019548CD2D7.jpg (43.9 KB, 10 views)
File Type: jpg 91829670-DFD9-4A4B-B8A4-8AB2CB76AA59.jpg (42.7 KB, 10 views)
67 Sedan is offline
post #4 of 5 (permalink) Old 01-30-2020, 06:13 PM
The retainers for a '68 side molding are a mixture of the push-in and threaded metal clips with the spring arm to hold them in.
post #5 of 5 (permalink) Old 03-18-2020, 03:15 PM Thread Starter
Look the same, not the same!
67 and 68 sound the same, just donít know if they are the same size. The ones I bought are too big. As I try to modify them, the outer lip that keeps it attached to the trim is ground off, thus rendering unusable. Iíll keep looking!
File Type: jpg EBF88EEB-9886-47F4-90C6-0BC19B4E91DA.jpg (27.8 KB, 4 views)
File Type: jpg 22EC8262-3D4F-4328-8960-C9036B12D447.jpg (29.7 KB, 4 views)
67 Sedan is offline
