63 Pro Street Project - Impala Tech
 2Likes
  • 2 Post By Deadwolf
post #1 of 6 (permalink) Old 05-25-2020, 08:36 AM Thread Starter
After getting the bad rocker replaced and cutting out the floor I brought in a guy to blast the body to metal. Let me tell you that this process will find all the locations where your sheet metal is thin. Most people doing a restoration would probably write this body off, but that is the reason I chose it for a Pro-Street build. Once you modify a body for Pro-Street it is next to impossible to ever take it back to a factory build.
My daughter has taken an interest in the project as well and in one of the pictures you can see her applying the epoxy primer. I was really surprised that this can of Dimension DP800 Epoxy Primer still mixed and applied good after sitting in my unheated garage for 12 years. Tonight I'll see how well it stuck to the metal.
Name:	Set up for blasting A.jpg
ID:	23576   Click image for larger version
Name:	Set up for blasting B.jpg
ID:	23578   Click image for larger version
ID:	23580   Click image for larger version
Name:	Epoxy primer application.jpg
BA. and 67 Sedan like this.
post #2 of 6 (permalink) Old 05-30-2020, 08:52 AM Thread Starter
Got to working on the fire wall. The passenger side cowl panel was pretty bent up, unfortunately I had left my cell phone at work on the day I started it so I don't have any as found pictures. But in the picture with the section cut out you can see the part above that I had to hammer and dolly to a semblance of straight. Then you can see the panel I fabricated fit up and ready to be welded in. If this was more of a classic restoration I would probably take more time to get the fit and look more like a factory panel. Also would have replaced the outer cowl panel as the lower lip took a lot to get straight and is missing some pieces. In a pro Street car though nobody will ever see it. Was going to buy factory heater delete plates, but after pricing everything up (Less than $20 of steel and some mig wire) I decided against the $70 delete plate and will just fab up some steel and weld them shut. By the time the frame is done this car will not be able to go back to an original configuration without considerable amounts of work, as the frame is welded to the body.
Name:	Cut out lower cowl.jpg
ID:	23594   Click image for larger version
Name:	New lower cowl mock up.jpg
post #3 of 6 (permalink) Old 06-29-2020, 01:49 AM
Looks like you have lots of things to do. Good luck and keep us posted.
cedgar is offline
post #4 of 6 (permalink) Old 06-29-2020, 10:54 AM Thread Starter
I've made leaps and bounds of progress on the firewall. Attached are some pictures. It shows how I fit things up. Unfortunately I can't find after welding pictures. The next picture is of the all Metal applied, followed by a skim coat of bondo. The last picture has it in POR-15. I will sand the POR-15 with 320 grit then apply a flatter black, not a good idea to use gloss under the hood as anytime a chemical splashes on it, it discolors a little.
Name:	Blower motor plate.jpg
ID:	23684   Click image for larger version
Name:	All metal cowl.jpg
ID:	23686   Click image for larger version
Name:	Bondo cowl Passenger side.jpg
ID:	23688   Click image for larger version
Name:	Bondo cowl driver side.jpg
ID:	23690   Click image for larger version
Name:	Por-15 firewall.jpg
post #5 of 6 (permalink) Old 06-29-2020, 10:59 AM Thread Starter
Now I have moved on to the front of the passenger side quarter panel. I should have just bought a full quarter for this side, but live and learn and now I get lots of practice piecing things together and probably tons of sanding later. Looks like I will have to split the panel and put a small filler piece in to stretch the panel so the upper body line matches the door. But since this isn't the door I will use I will have to buy the new door before I start that process. This door has a lot of bondo in the lower part of the door and the lower part of the door seams to be a little out of wack. I guess I will move to the drivers side while I wait for the new door.
Name:	PS quarter cut out.jpg
ID:	23694   Click image for larger version
ID:	23696   Click image for larger version
Name:	PS door to panel fit bad.jpg
post #6 of 6 (permalink) Old 06-29-2020, 11:56 AM
Looking good man!
Your first picture there of the front-quarter section cut out reminded me of the total PITA I had trying to get a good weld there on my own Imp. I'm not a welder but was learning and the cheap Asian replacement part I had was blowing through easily compared to the factory quarter. Ugh!!! Hard and painful lesson there....
Good luck - keep at it!!
