66 Dash lights not working... - Impala Tech
post #1 of 7 (permalink) Old 08-20-2020, 12:20 PM Thread Starter
Hi...Replaced the headlight switch and got all the lights , exterior, working except for back up lights.
I have no dash lights when I turn on the headlight switch, but turn signals, high beam, indicators work.
Any help on where to start looking appreciated....
HalnasLT1 is offline
post #2 of 7 (permalink) Old 08-20-2020, 12:51 PM
Have you checked the fuse box?
Whenever you are working on your electrical system you should always disconnect the negative terminal at the battery and only reconnect it after checking your circuits with a multi-meter first.
Big dave
post #3 of 7 (permalink) Old 08-20-2020, 04:53 PM Thread Starter
Hi Dave.... God idea, but the dash is in the car already. I'm restoring it and need the dash lights to work for the safety certificate.
There are some gauges under the dash and the lights work on them. Was hoping for a "clue" on where to start and if this is a common issue. Could it be the circuit board on the speedo cluster?
TIA
post #4 of 7 (permalink) Old 08-22-2020, 08:35 AM
Are you sure they're not just turned all the way down? If they aren't, the feed for the dash lights on the light switch is faulty or not in the right place.
Craig
66 Impala (in progress)
56 stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
craig32 is offline
post #5 of 7 (permalink) Old 08-22-2020, 10:30 AM Thread Starter
I installed new headlight switch, that fixed no tailights/signals and courtesy light staying on. There are aftermarket gauges with lights under the dash, they work and I can see the brightness change when the switch is turned...
THX
post #6 of 7 (permalink) Old 09-02-2020, 10:46 PM
Good to know. Where did you get the new switch?
dreison12 is offline
post #7 of 7 (permalink) Old 09-02-2020, 11:04 PM Thread Starter
Hi.... Got everything figured out. Been along time since I had an old car. Had the headlight turned down thinking it was going to be brighter turning it down, main reason was there no ground to the cluster. Ran a jumper wire and lights on 8 of the 12 sockets. Need a circuit board which I found on Ebay. Should fix my problems....
Dreison12.... rock auto, napa, still readiy available
Thx Guys for trying to help
