'61 Vent window drain rubber - Impala Tech
post #1 of 4 (permalink) Old 01-04-2012, 02:36 PM Thread Starter
Does anyone know where i can find the drain rubber for the vent window assembly? I replaced the glass and rubbers, rechromed and polished SS on the assembly. But when I was putting everything together I noticed a drain rubber (what's left of it) on the bottom of the assembly. There is a metal plate that holds a rubber/gasket piece (approx 5") that has a notch for the vent arm to regulator and a square nipple (looks like a drain). I've called all the major suppliers, no luck! I know it's a minor piece but I figure I've done alot of work to overlook a simple rubber. Any guidance is appreciated.
' 61 Impala Sports Coupe
Visit my blog:
http://www.impalas.net/forums/blog.php?u=2764
Buggin58 is offline
post #2 of 4 (permalink) Old 01-04-2012, 02:37 PM Thread Starter
Also, I've looked through the assembly manual and shop manual but there is no reference to it.
Thanks
Visit my blog:
Buggin58 is offline
post #3 of 4 (permalink) Old 01-16-2012, 02:32 PM
Hmm...
I think I recall something there...however my doors are all buttoned up and all works as it should...and really hate to pull it apart...
I searched and could not find anything either....
You could always put it together and if you ever run across the pieces...then install.
Would imagine where/how the water would drain...it all ends up in the door anyway...
Brett
hammerit- is offline
post #4 of 4 (permalink) Old 01-16-2012, 05:01 PM Thread Starter
You're right, I'll probably just reuse the old ones.
Thanks Brett.
Visit my blog:
Buggin58 is offline
Tags
drain, gasket, rubber, vent window
