rear seat back - Impala Tech
post #1 of 3 (permalink) Old 03-01-2014, 04:37 PM Thread Starter
rear seat back
I know how to remove the rear seat bottom, but how do you remove the rear seat back from a 63 Impala convertible?
japete92 is offline
post #2 of 3 (permalink) Old 03-02-2014, 09:37 AM
If you feel under the seat about 6 inches from the corners you will find a bolt. Unscrew both of them then raise the back straight up. On the top are two hooks about 2 to 3 inches long so you need to raise it about 3 inches. You will know when it is loose then pull.
Txbobcat is offline
post #3 of 3 (permalink) Old 03-02-2014, 02:51 PM Thread Starter
Thanks. Sounds easy enough. I was lightly tugging on it like one would do on the bottom and it wasn't budging.
japete92 is offline
