1965 impala ss convert What did they use - Impala Tech
post #1 of 7 (permalink) Old 06-02-2014, 08:37 PM Thread Starter
What oil did they use in the pump motor and cyls
I am cahnging mine Some people say auto trans fluid is good?
Mine had a clear oil in it maybe hyraulic oil or mineral oil
modela1929 is offline
post #2 of 7 (permalink) Old 06-02-2014, 09:57 PM
Trans fluid or brake fluid. If yours is clear, I would guess brake.
post #3 of 7 (permalink) Old 06-03-2014, 07:59 AM
Which device are we thinking of changing the fluid in? Power Steering reservoir?
Motor oil in the engine? Transmission fluid for an automatic transmission, or a manual they are different!
post #4 of 7 (permalink) Old 06-03-2014, 09:50 AM
He means the top pump/lines/cylinders. FWIW, there is ATF in mine.
post #5 of 7 (permalink) Old 06-03-2014, 02:46 PM
I would use power steering fluid. Power steering fluid and ATF differ very little chemically. The red dye in ATF is used as an indicator of overheated fluid. It turns brown when it gets hot or old. Both are high quality mineral oil based hydraulic fluid designed to resist foaming.
post #6 of 7 (permalink) Old 06-03-2014, 05:49 PM
My parts are new and I used ATF in mine just because i had it around.
post #7 of 7 (permalink) Old 06-04-2014, 05:34 AM
Mine came with brake fluid, thats whats still in it. Do not, whatever you do mix, the two. They dont play well togather.
