1965 ss convertible - Impala Tech
post #1 of 5 (permalink) Old 01-23-2009, 11:50 PM Thread Starter
1965 ss convertible
I am in the middle of installing a 1995 LT1/T56 combo into my Impala. I have already air bagged it , Autometer Cobalt gauges, 20" foose wheels, 4 wheel disc brakes, camaro power seats, among other upgrades. Question is, about the transmission crossmember, has anyone heard or done this?
I can't seem to find on in the aftermarket and any that I have found are for the Tremec 5 speed conversion and they can't tell me if the transmission mounting bracket will match up. I have checked with Street and Performance and they can sell me a automatic crossmember that I can mount to the insides of the framerails to adjust the position, but of course I would like to use the stock position.
Any help would be appreciated
ruff12 is offline
post #2 of 5 (permalink) Old 01-24-2009, 10:29 AM
Do you have the original crossmember? Im sure it can be moved forward or backwards or modified to work.
post #3 of 5 (permalink) Old 01-24-2009, 11:27 AM
You've probably thought of this already but in the swaps that I've followed, I've noticed these 3 fixes for other cars.
1. Aftermarket custom X-member. (sounds like we don't have one for this swap)
2. Leave X-member bolted to tranny, drill new mounting holes on frame.
3. Cut original X-member into 3 pieces, bolt them in place, then weld/fabricate together as necessary.
I've not heard of any aftermarket X-members for the Impala.
post #4 of 5 (permalink) Old 01-25-2009, 08:06 PM
We now have Tremec on line as a sponsor here so I am sure they will provide you with the info you need. Just forward your question to them.
post #5 of 5 (permalink) Old 01-31-2009, 03:42 AM Thread Starter
I tried moving it back and forth,flipped it over and rewelded the mounting bracket. problem is that the tailstock on the T56 is lower so that crossmember hits and I need that -3 degrees for the correct pinion angle.
I ended up ordering the powerglide one and looks like it would fit.
thanks anyways
ruff12 is offline
