-   Restoration Corner (https://www.impalas.net/forums/8-restoration-corner/)
-   -   68 big block a/c brackets (https://www.impalas.net/forums/8-restoration-corner/37814-68-big-block-c-brackets.html)
bicster 05-19-2019 07:57 AM
Hello all, Tried posting wanted add but could not get it to work. I am looking for a set of a/c brackets for my big block 68. Compressor on passenger side. Do not need the compressor just the brackets. Do any of you have any for sale or know where I can buy new? I find them new for the drivers side but not the passenger side. Also need a fan shroud for the big block. Thanks for your help.
Big Dave 05-19-2019 10:48 AM
Big block was installed in a lot of Chevy car bodies (Camaro, and Nova in 1968, and the Chevelle and full size cars as well as the light truck from 1965-'68 (the time period that had a BBC and a short water pump). All BBC engines were made in Tonawanda, NY and they fit in all of these vehicles with or without A/C so the brackets are all the same on a short water pump.
Notice I didn't mention the Corvette. This because of the sloping hood line all of the accessories are mounted low to clear the hood and use Corvette only brackets.
bicster 05-19-2019 09:42 PM
Thanks Big Dave, My project I am working on is a 68 ss Impala. I removed the 327 and installed a 1972 454. I was able to reuse the crank and fan pullies. Purchased a new water pump, alternator and power steering brackets and everything fits perfect. Now need the a/c brackets. My small block brackets will not work. Yes, 1965 through 1968 BB should work.
Big Dave 05-19-2019 11:26 PM
Small block crank and fan pulleys bolt to the engine because Chevy loves interchangeable parts. HOWEVER the belt will not align with anything else and will be thrown every time you rev the engine. A BBC has it's own pulleys and brackets (three sets of them for V-belts and three for serpentine belts) in fact. Everything must match your application.
There are belts and pulleys for a short water pump and for a high performance engine (has solid lifters from the factory) with a short water pump. There is a different set of belts and pulleys for a long water pump. Serpentine belts come in one belt five or seven rib, or a two belt system with only five ribs (difference is direction of rotation of water pump which is the long pump style).
Different power steering pump pulley if car had A/C or not and a long pump which differed from the short pump (one groove PS pulley only).
If you want to search on line and buy parts by Chevy part number they are all listed on Team Camaro in the techinical section (accessories and engine were the same in the Camaro and the Nova as well as the Impala.
bicster 05-20-2019 08:08 AM
Good info Dave. Here is what I did, Long water pump, used the fan and pullies from the small block also the power steering pump, purchased new big block alternator brackets and power steering brackets, new V-belts and they all line up perfectly. Wanted to keep the original look. If the alternator and power steering line up perfect I thought the an original set of a/c brackets would line up also. Thanks for the info. I will look for the part #'s. I purchased a new 4 row radiator so now my small block fan shroud is to wide and hits the power steering pully . Last night I trimmed off 3/4 inch from the shroud and it fits and looks good. I no longer need a fan shroud. I will post a picture. Thanks
bicster 05-20-2019 08:30 AM
4 Attachment(s)
Here are some pictures of the project.
bicster 05-20-2019 08:34 AM
My mistake in the parts description. A short water pump not a long pump.
62BillT 05-20-2019 08:42 AM
I've got some AC Brackets available for a Big Block, but for mostly for late '60's and '70 cars. But if you can produce some Numbers of the parts you are looking for, I'll check to see what I can find.
Bill
Big Dave 05-20-2019 12:43 PM
Here are the pulley numbers for the 1966-'68 375 horse 396 which has a lot of reproduction parts so you may be able to find parts a little easier:
L78 Used a deep "V" pulley to prevent throwing belts
Crank pulley 3869978
Crank extension 3906656
Water Pump pulley 1970831
Alternator pulley 3925522
Power Steering pulley 3873847
All of these pulleys have the part number stamped into the metal.
Here is the CRG information on the BBC factory pulley list for 1968 production year (short water pump).
http://www.camaros.org/pdf/pulleys-68-2007-02-01.pdf
and here is the Long water pump pulley list (1969-'04):
http://www.camaros.org/pdf/pulleys-69-2007-02-01.pdf
bicster 05-23-2019 11:58 AM
Thank you all for your help. After much research I have decided to go with a sanden a/c compressor and brackets. Lighter and cleaner look. Thanks again.
bicster 05-25-2019 11:34 AM
For those interested in the part #'s of the a/c brackets and for 62BillT,I think I got them. ( Some one correct me if I am wrong.) Looks like chevy used 2 different styles. One with the rear adjusting brace over the valve cover and one not over the valve cover.
Part #'s for no brace over the valve cover
3872785-bracket, front
3878268-bracket, rear
3921950-brace- rear
3878269-brace-support
3928906- mounting stud
Part #'s for the rear brace over valve cover
3872720- brace, rear
3906682- brace, front adjusting
3872726- brace, support
3872785- bracket, front
manual transmission does not use the 3872726 support brace
