(https://www.impalas.net/forums/)
- Electrical & Wiring
(https://www.impalas.net/forums/16-electrical-wiring/)
- - Headlamps turning off when Hi-Beam engaged
(https://www.impalas.net/forums/16-electrical-wiring/37818-headlamps-turning-off-when-hi-beam-engaged.html)
Interesting one.
I recently replaced my old Hi-Beam headlamps after one of my old ones died with 5-3/4'' Xenon Conversion Headlamp Bulb (High Beam). Put them in, switched on and aligned them and all was good. When I finally got around to driving and needing them I engaged the Hi-Beam footswitch and all of the headlamps went out! Not great considering I was driving at the time. After I disengaged the Hi-Beam switch my main headlamps came back on. The only difference I can see is the replacements have three pins rather than two but they worked fine when I first put them in, hence why I was able to align them. Thoughts? |
Bad switch. They get full of dirt and the contacts are blocked as well as being under a heavy electrical load when they work resulting in pitting and burning.
Big Dave |
I'm not disagreeing with Dave here, not at all. Those old switches get troublesome with age....but,
Excuse my ignorance or presumption here but wouldn't/shouldn't a Xenon bulb use a breaker near the headlight with its' own 12v source so that the extra wattage doesn't flow through the 50 yr old wiring? |
Good point Dave. 40 years ago I experienced the same problem with a car I had and it ended up being the high beam/low beam switch on the floor. If the new head light switch doesn't fix it try the switch in the floor.
UPDATE:
Just thought I'd post that I cleaned the footswitch and connector with Electrical Cleaner and an old toothbrush, let it dry and it's working fine. Hopefully I don't have trouble with the Xeon bulb drawing too much power as B.A mentioned but for now all good. Thanks for your help! |
User Alert System provided by
Advanced User Tagging (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
