-   Steering (https://www.impalas.net/forums/66-steering/)
-   -   1966 Impala Steering box (https://www.impalas.net/forums/66-steering/38330-1966-impala-steering-box.html)
lndbarron 11-26-2019 06:27 PM
Hello, I just completed a suspension update/overhaul to complete the rebuild I want to tighten up the steering. What is the correct ratio needed for a stock steering box. Can the box be bought aftermarket or does box need to be rebuilt?
68WASAGOODYEAR 11-26-2019 07:29 PM
You can buy a stock Lares steering box with the correct ratio off of Rock Auto. It will be a remanufactured unit. You can also get the stock box with a faster ratio as well. I went from 4.5ish turns lock-to-lock to a 3 turn due to a tight turn getting into my garage. It was a good upgrade.
Beware anything aftermarket - if it changes the Pitman arm location, angle, etc. and thus the steering geometry, all that hard work you just did overhauling the suspension will be for naught as you won't be able to get it aligned.
BA. 11-26-2019 07:33 PM
Most people would say that the stock steering box is over-power-assisted and too many turns lock to lock.
If you agree, you may want to steer clear of a stock or rebuilt stock box. There are many other units that swap right in place, and a few available on the aftermarket that are very nice as well. Just a matter of $$.
Some folks have used a 70's era Z28 or Trans Am box. I personally had heard the 79 was 'the one to get' and got lucky and got one for $50 long long ago for a different car. I bought my Impala replacement box from Lee's Steering because of their reputation.
I think a Jeep Grand Cherokee box can also be swapped in (cheap and plentiful!), but always ask about (think about) which ones have a Standard hose fitting versus a Metric fitting. They make hoses and even fittings to adapt - just know what you need for the box you end up getting.
I believe a few others have used the CPP unit that they sell. Not sure if it's good or durable. I believe Lee's had mentioned our Full Size cars use an '800' series unit which is slightly beefier than what you find on some other cars.
sz0k30 11-28-2019 11:21 AM
And if going to a different box, keep in mind that different vehicles sometimes required different internal stops that will effect turn radius.
Big Dave 11-28-2019 12:31 PM
They are internal, but they are adjustable if you know how (Information on rebuilding the steering box can be found in the Chassis Service manual for your year car). If not there are specialist on line that will sell you a rebuilt box off a Corvette that will bolt up to your Impala set up for your turning radius (stops set to keep the tires from hitting the frame). Keep in mind that GM went to a metric fiber rag joint in 1976 so any box from a later car will need an aftermarket adapter to bolt the steering column to the box.
snoopy1 12-05-2019 07:49 PM
I used the steering box out of a 97 jeep GRAND Cherokee, 3 turns lock to lock, handles great, stops are perfect, had new hoses made which I had to do anyway since I'm LS swapped. I'd never go back!
Big Dave 12-05-2019 08:18 PM
Jeep division of Chrysler uses the same Saginaw box that Chevy uses (Jeep used to buy tranies and engines from Chevy as well so there are a lot of parts that interchange even though Jeep made their own head). Additionally Ford uses Saginaw steering gear boxes on their intermediate cars.
Comes from a desire not to reinvent the wheel when there is a cheap solution to a common problem.
67SS 12-12-2019 03:47 PM
I bought a Lares steering box from Rockauto. 3 turns lock to lock and it bolted right in, no adapters, no changes in pitman arm location, no changes in geometry. Finally the boat doesn't float all over the freeway.
wk2hons 12-24-2019 09:18 AM
I also have a 67 Impala and would like to get the Lares box from Rockauto . 3 turns lock to lock, but it says you need a different coupler rag joint, But it doesn't say what one. Also do the stock hoses fit this box, and is it the same outside profile. My headers had to be formed in for clearance around the box (very close). Rockauto doesn't seem to have tech support to talk to. So any input would be great.
Big Dave 12-24-2019 12:07 PM
There are adapters to go from the SAE or "English" steering boxes to mate to the newer metric boxes. Different spline count and shaft size is what you are compensating for, and this is a very common upgrade. Same for the hoses. You have a Compression Flare fitting on your old SAE box and newer Metric boxes use O-rings to seal. There are adapters to mate your old hoses, or the best solution is to have new hoses made at NAPA to match length and what you have for fittings.
Real problem that no one addresses is that these new Metric boxes are smaller (800 series instead of the heavier duty and older 600 series). These new metric boxes are off of 3,200 pound Monte Carlos, or 2,800 pound third gen Camaros. Not the strongest match for a 4,200 pound lead sled of an Impala if you are going to push the barge by trying to autocross it.
