-   Performance (https://www.impalas.net/forums/4-performance/)
-   -   Suspension rebuild (https://www.impalas.net/forums/4-performance/38426-suspension-rebuild.html)
Rpinney1 01-08-2020 06:25 AM
Suspension rebuild
I am in the process of rebuilding my 66 from ground up. I am reusing my stock front control arms but want to do a 2”drop. I have found alot of info but also conflicting. What parts do i need to reuse stock control arms ? Drop spindle only or combo of drop spindles and drop spring ? Stock height spring. Offset upper control arm bar ?? I dont have much knowledge on steering geometry. Just want to order the correct parts without changing control arms. Thanks
68WASAGOODYEAR 01-08-2020 08:35 AM
Get 2" drop spindles and leave the stock steering geometry alone, including the springs.
Brandon Hendricks 09-02-2020 07:45 AM
I see. Thanks for the tip, man!
justjohn 09-02-2020 09:03 AM
CPP spindles are most compatible with aftermarket brakes if you think you might be going that route.
