-   Transmission & Driveline (https://www.impalas.net/forums/12-transmission-driveline/)
-   -   '63 Impala drive shaft busted fuel line... (https://www.impalas.net/forums/12-transmission-driveline/8117-63-impala-drive-shaft-busted-fuel-line.html)
Goldie63 04-01-2013 06:57 PM
I have a '63 Impala 327 powerglide. In the middle of the central tunnel of the x-frame, apparently my drive shaft became loosened and was knocking around. While it was knocking around it busted my fuel line right in the middle of the X.
Any Ideas why this happened?
Thanks in advance!
~Steve
Big Dave 04-01-2013 07:34 PM
Your carrier bearing failed. Your car is half a century old parts wear out.
Beware of cheap corner auto parts store replacement carrier bearings which are made over seas (specifically the Pacific Ocean and most of the Indian Ocean). They will not last years never mind the decades that the Factory original lasted. Some are replaced within months of installing their first carrier bearing. The local auto parts store will cheerfully give you another cheap replacement when you bring it back complaining, however they will not reimburse the labor to install it over and over again.
http://www.summitracing.com/parts/ie...63?prefilter=1
Txbobcat 04-02-2013 09:10 AM
You were lucky. It could have come up thru the floorboard and ended your sexlife
Goldie63 04-05-2013 08:57 PM
Thanks Guys, I love this forum.
I hope I can repay the favor of imparting info sometime.
~Steve
