The 327/300 engine that was originally in the car would have had the VIN number stamped on the block to prevent theft of a high performance engine. This would be how you would tell the difference between a car with the 327/300 and a 283 car. 283 blocks don't necessarily have the vin stamped on them as they were not classified as a performance engine at 195 HP. Not sure about 1964, but in 1963 you could also tell the difference by the fuel line coming from the tank. The 327 and 409 had a larger fuel line with a return line to the tank. If you have that return line then you could look at the radiator and as long as it is original, the size of it would indicate a 327 or a 409. Also if your fan is currently properly placed in the fan shroud and it is a factory fan shroud then your car was most likely a SBC and not a W.
Now with that said all of these things can be installed currently with aftermarket parts making it very difficult to know what a car had. You can even have an engine block re-stamped with the VIN.
Nice looking car. You have the same color as mine on the exterior, but my interior matches the exterior color, so no white seats for me. I was originally going to repaint it red during frame off, but the factory color is growing on me.
