· Registered
Can someone please post a picture or explanation of what the interior trim looks like around the rear window of 1968 2 door hardtop (not a fastback)?
I inherited the car and it was already removed and I think I'm missing the corners maybe? I have three metal pieces: one long arc-shaped piece and two L shaped pieces that overlap and screw together in the middle. Seems like there should be corners or something to connect it all together, but I've never seen one finished.
Any help would be appreciated - thanks
· Registered
Don't know if you are still looking for help with this ??
I've searched the net and can't find any pics of a rear window...:(
Have you tried holding the pieces up on the outside and see if there are gaps where corners would be missing ? If you look at the outside trim on the windshield, they fit under the upper trim in a "slot". See if the long arc piece has those slots in the ends for the L shaped pieces to fit under.
